Siemens step7 pointers
rebetiko
Dec 2012
portsmouth
Hi every one.
I am trying to verify the following:
A DINT can be converted to a POINTER by simply shifting the double word left by 3 bits.
i want to prove that DINT 160 results in P#20.0 after a SHL3 on 160.
can some1 prove it by means of an example?
its doing my head ?
1010 0000 = 160 (DINT)
if i do a SHL3 in the above , i get 0000 0000 (?)
but if i do a SHR3 i get 0001 0100 which is 20 (for P#20.0)
so
is it a SHL3 or a SHR3 that converts DIN160 into P#20.0 ?
Many thanks 2 all
Hi every one.
its doing my head ?
so
Many thanks 2 all
From my head. For starters, you say you use a DINT but your examples shows shifting bytes.
SLD 3 on 1010000, which is actually 2#00000000000000000000000001010000, would produce 2#00000000000000000000001010000000
I think 160 is
10100000
A0 in hex
The pointer format is
XXXXXXXXXXXXXXXX.BBB
I think the 160 might already be in the correct format for
0000000000010100.000
P#20.0
Where is the 160 coming from ?
Maybe try
L 160
LAR1
the contents will then be 20.0
As aready stated, 160 dec is P#20.0 when shown in pointer format.
The coding for converting to pointer format is as below:
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
156
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
152
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
544
Hi, I received a Step7 Backup from my client and tried opening this backup but it won't open as there seems to be files missing from the backup...
3,029
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,258
