polarity reversal question
gatfu
Jan 2013
kansas city
62
I have an AB 1100 fully populated with expansion modules. everything is pretty much in use except for some of my openings on my 1762-ow16 module. i still have a few openings on this. what i need to accomplish will be tricky however i think it can be done i am just not sure on how to go about it. i need to add an actuator to my sequence that will open and close upon polarity reversal. this actuator is normally controlled by a manual hand rocker switch to accomplish this however i am trying to eliminate the "Manual" part of this and integrate this into my fully automated sequence. obviously i can't polarity reverse via software something that is directly connected to my output. There has to be something in the middle that can handle this however my mind is drawing a blank. I am thinking maybe blocking diodes of some sort but am not fully sure. any thought, ideas or help is greatly appreciated.
Double Pole Double Throw Relay. Hook Device to Commons on Relay. Use Contacts to Reverse Polarity. Output on = (+ -) Output off = (- +)
That should work if there is no off position. Might need another relay for that.
Stupid newby question... i'm sure it will work but can you throw a DPDT relay on the out put of another relay? in other words i guess it will just be two relays in series. the first relay in the expansion module when it makes it will activate the coil in the external relay (DPDT).
there will need to be an off state. i can't be driving 12 vdc constantly in either direction. it will only need to drive to open or close then the circuit will need to break again.
If Device current is not greater than Outputs Max Current then you could do this. If current draw is to much then an additional Relay will be needed.
VIOLA...i believe that will work. the device current draw is only 60mA. Thanks a million for clearing the fog in my head!
This is a CompactLogix L33ERM, version 30 (31 is too unstable on my machine to work with), with a Kinetix 5500 drive. I have a program where...
2,032
For negative polarity Zener barrier , the cathode of the zener diode is connected to ground...So how this circuit work for DC supply?? as per my...
1,695
I have a Panasonic PLC running 3 motors and they have to reverse direction after a timer. It currently uses one FP16 module with positive...
2,993
Hi, Please refer to the attached sketch. There is a 4-20mA transmitter and receiver working as shown in "Current Setup". Now, I would like to...
3,093
Hi all, I have an anlaog 0-10vDC signal from a chrome plating rectifier to a AB 1746-NI8 module.The problem is the chrome plating has a deplate...
4,832
