Hello all,
I was curious if there is a way to create a "windows" type pop up window and button in EZ Touch. I have been working with it, but not quite working like I want. What I have....when operator presses button A it should activate look up text and a button (button B). Text asked "are you sure" if so press button B. When button B is presses it will shut of a motor. The perpose is to prevent turning off the pump by mistake. I have the look up text working with the correct message. I have button B hiding and apearing. Main issue seems to be with the A button. When I press it and the text and button pop up I press button B but button A stays on..... Hope this gives you enough information to understand what I am trying to do. Thanks for all the help.
Micheal
Micheal
