Pop Up Window - PanelView Plus
Burch
Jun 2014
Michigan
54
I'm asking a fair amount of questions today, thanks to all for the help!
Anyhow, here is another.
I have an application with recipes. Pretty sure most of the HMI and (as far a I can tell) all of the PLC portions are working.
In my recipe edit scree, I have a "Accept Edit" button. When pressed, the values entered via the HMI are stored in an array of UDTs in the PLC. What I'd like to have happen is a pop up screen "pop" up to tell the user this has happened, and then when they press OK, the pop will close, and the recipe edit screen will be cleared...and ready to enter another recipe.
Any tips?
Thanks,
Burch
If you aren't using the Remote Display Number global connection, You could setup some PLC logic to set this when the PLC recieves the edit.
Then assign your 'on top' display to that number and have the "OK" button clear the Remote Display Number and then close the display.
I am using a HMI from PROFACE (GP-4502WW). There is a limitation where I can only include 1 global pop out window. However, there are 2 global pop...
1,428
I have a comparative program in M340 PLC in which when a condition is true a memory bit is set to high. I would like to Pop UP a new window every...
2,408
is it possible to have pop-out windows in factory talk? So far I have only succeeded in "pop over" windows, but they always display on top of the...
4,785
I have an application where the customer would like to have a window (pop up/faceplate) open given certain states of field devices. For example if...
1,612
Hi Everybody, I have been using RSlogix5000 for quite a while and did a few big projects. One thing is annoying me, when I right click a tag to...
2,968
