Ports 0 and 1 on the SLC 5/05
godfrey
Apr 2002
Charlotte, NC
412
If I connect my computer to port 1 and a panelview to port 0 of the SLC 5/05, can I download to the panelview using Panelbuilder via the port 1/computer connection? If there is documentation describing this can you point me to it?
Here's a great technote that describes exactly the steps to do this:
G17728: SLC-5/05 Ethernet Passthrough DH485 or DF1 PanelView on Channel 0
I learned a long time ago that there's a difference between "communication works through this path" and "PanelBuilder32 can download through this path". The packets in a PanelView download area lot bigger than typical message packets and the transfer utility often lags behind RSLogix or other RSLinx clients in it's ability to use an unsual or complex communication channel.
I like the EtherNet/IP PanelView terminals... they're more powerful and flexible than any of the others, though a little pricier. Plus you don't have to mess with Passthrough.
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,251
I thought I read somewhere the newest SLC 505s suppot modbus natively on the RS232 port. But now I cant seem to find info on it. Was I dreaming...
3,172
Hi, I want to connect a Panel View 300 through Ethernet to an SLC-5/04.But my PLC support RS-232/DH+ and would appreciate some advice on...
4,332
Hi all, This is a really quick and easy question for anyone with Allen Bradley knowledge.. specifically on an SLC 5/03 CPU. There's two ports on...
5,161
Hi, does anyone know what ports CLX ENBT, SLC's, PV+'s etc use on tcp/ip protocol? IT are setting up our firewall and are asking tricky...
1,934
