SLC 5/03 CPU (What ports are there?)
Johnny T
Jul 2003
Fife, Scotland
642
Hi all,
This is a really quick and easy question for anyone with Allen Bradley knowledge.. specifically on an SLC 5/03 CPU. There's two ports on the front. The top port looks similar to an ethernet connector and the bottom port is some kind of D-Type 15? pin connector.
What comms protocol does the top port use? Is it DH485? Or is it set up in the software?
I have the software in front of me and under Channel Configurations I've got..
Channel 1 - DH485
Channel 0 - DF1 Full Duplex
(I'm not sure if this reflects the protocol of the comms ports on the front of the PLC or not.. and, if so, which is Channel 0 and which is Channel 1)
Many thanks for any help you can give me..
Cheers
JT ;-)
Channel 1 is the ethernet lookin port that is for some personal computer interface. I dont have much knowlage on that.
The D connector is channel 0 its the DF1 port, use this to connect your laptop, using cable 1747-Cp3. Or there are some diagrams on this site with the pinouts.
Thanks lads..
(Synchronised postings there!)
I suspected the top one was probably DH485 but needed to be sure.
Appreciate the (very) quick response.
Cheers
JT ;-)
The SLC5/03 does NOT have ethernet! That's the 485 port. Typically accessed via a PIC module.
STOP!
Do Not Plug An Ethernet Conntection Into The RJ45 Port On The SLC5/03!
Unless you want to buy a new ethernet card for you PC, or worse, a new laptop if it has a built in port. The RJ45 Port on the SLC5/03 has voltages present on it that will damage your ethernet card.
Can attest to that!
Had a vendor supplied skid with a Panelview. The vendor changed out the Panelviw & rewired it with L1 & L2 swapped. Stopped by to chat with him and he asked me to plug in the RJ45 connector into the processor. Not only did he have to replace the Panelview, but the backplane, processor & buy pizza for the shop.
evilpig said:
Can attest to that!
Not buying this one. Why or HOW would the vendor change the power supply?
yeah sorry i knew that, just maybe didnt make it clear, it LOOKS like an ethernet port. I know i guy who pluged his lap top direct into that with an RJ45 cable, Didnt do much good.
The DB9 plug is software configurable to be many things in an SLC 503. It can be DF1 in its many guises, you can also configure it as a DH485 port or as an ASCII port.
Regards Alan Case
I didn't say he changed the power supply. He wired the panelview with the hot & neutral swapped. The RJ45 connector on the processor is tied to common.
I used up my last new Allen-Bradley SLC 5/04 controller. Does anyone have info on a good reliable place to get a new one for a decent price, or...
527
hello at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller. I'm...
3,022
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,808
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,057
Hello, first of all, I want to say thanks to everyone who is seeing this post. I have a problem with an SLC 500 5/05 processor. I need to download...
2,800
