Positive displacement flow totalizers
dwoodlock
Nov 2012
Cincy/nKY
568
I have a CIP I am working on to acquire data about our oil consumption for our process, but also bearing oils.
I wanted to make a flow totalizer a part of it, but have had poor luck so far.
I am to blame for the poor luck, as I bought flow meters that were not designed for low flow systems.
The system is pressurized oil, that refills tanks, when the valves on the supply tanks open. 12gpm max air pump maintains the pressure in the line, and the trunk is 3/4".
I am now looking into a positive displacement totalizer/transducer, but wanting to hear some opinions if anyone has experience.
I am thinking although the trunk line is 3/4", for precision of measurement, I may adapt the line down to 1/2" as the smaller the transducer the more precise measurement of the flow. Most of the feed valves for the system are probably 1/4", but multiple can be turned on simultaneously. I highly doubt flow will ever approach 12gpm.
Could you detect the level changes in the receiving tanks or monitor the change in weight of those tanks?
positive displacement means a quantified amount per 'shot' of the pump so could you just measure pump operations and calculate pump shots per minute?
EDIT Sorry i see you put totaliser not pump
Hello All, I am using a acqoustic type flow meter made be flexim. I am controlling my pump with a PID loop. Has anyone been successful trying to...
6,187
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,119
Hello I have got a problem with positive edge from "system clock memory byte" in Tia Portal. I would like to change byte"system clock memory"...
27
3,607
Hey guys I have 2 numric inputs, from my PV, and I need to know the differens between them. I use a sub Eg 50-20 = 30 But if they input 20-50 =...
1,121
Can anyone see why i am not getting an output on this? it is detecting a rising edge and saying that it is true but going any further to the...
2,404
