Possible to do READ MSG to PLC5 from Contrologix via Ethernet?
harryting
May 2002
Puget Sound
2,595
Is it possible to MSG to PLC5 from Contrologix via Ethernet?
I know it's possible to do write/read at the Contrologix processor to the PLC5 series but I also remember from somewhere that it is better to do READ.
Yes it is possible. I do it all time.
Be sure to have an array in the ControlLogix for the data, then have a PLC/SLC routing table set up - this can only be done offline. Then in the PLC5, just do a MSG Read.
I too recall that Reads were better than Writes. One personal reason, I don't like for data to "appear" in my data tables without being able to control them.
Remember that PLC-5E controllers haven't always had the CIP Ethernet protocol that ControlLogix uses. Your PLC-5E (or 1785-ENET sidecar) firmware has to meet a minimum revision to be able to do "Multi-Hop" messaging, which allows it to communicate with ControlLogix.
RA Knowledgebase Answer ID# 16780 has the minimum revisions of PLC-5E Series C, D, and E controllers that support CIP. Series F controllers have had CIP since launch.
PLC-5E Series C Rev. N.1
PLC-5E Series D Rev. E.1
PLC-5E Series E Rev. D.1
Thanks, guys.
It turns out the PLC5 is on DH+, I just thought it was on Ethernet because I have been talking to it via a RSLinx Gateway PC for many years (yet another senior moment). The PLC5 is Series E though.
The contrologic (L63) does have a DH+ card so I should be all set.
Last year, we had a measuring machine with a bunch of LVDTs. The data from these devices were read by LabVIEW. The LabView VI would make a bunch...
1,522
Is it possible to make individual Ladders read only or password protected? I'm not even sure I want this, but I'm trying to solve a problem...
2,122
Impossible - in the sense that this error is happening. Except, it is! Scenario: I have 4 GE touchscreens, all addressed properly by IP...
4,029
I need to read the system tool counter on a fanuc control, using Macro B. I have tried variable #4120 but this only supplies the last programmed...
2,195
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
