Potential free relays
You should check the specifications of the output relay for maximum current and voltage. Also be aware if you're switching an inductive load like motor or heavy duty contactor. The induced current when breaking such a circuit will eventually burn and/or weld your output relay contacts.
Greetings, I am designing a system (B) which must receive a signal from an outside system (A). When the signal is sent by system A, system B...
7,533
Hello, I'd like to measure is a free potential contact on/off with a datalogger. Can I do as described in an attached pdf-file? Thanks for help!
17
4,335
42,318
I found this article in today's news interesting ... as if we don't already have enough to worry about these days ... headline: here's a link...
2,406
Hi all, I am currently working on a project where i need the to get the Julian date from the PLC (which i have now done). But now the customer...
1,591
