Potentiometer wiring
bdossantos
Mar 2018
California
67
Wondering if anyone has dealt with this and had any idea what the wiring would be? Box says "Platine R/I-Wandler TL 42543 rechtsoffnend. I have looked online but havent found anything. I know this is not PLC related but was wondering. Thank you.
E2526F6E-D7CB-48A1-912C-D79621F33DBD.jpeg C074D046-22F2-49DA-A6D1-2C528DF87789.jpeg
I looks to me like it's an adjustable 0 to 20 ma source
maybe used as a POT where the only input is 0-20 ma
it requires a power source most likely 10 or 24 volt
Wandler means converter in german and rechtsoffnend means right-hander, however, technical German often is not directly translatable into English
It does look like it controls a motor
It appears that this company deal with electronic plating & you will probably find this is an old unit, looks like all their stuff is more cutting edge
Hello, We are currently working on a project that involves connecting a linear potentiometer to our Beckhoff PLC. After researching, we...
197
I have been assigned a task to display the output of a potentiometer to a Mitsubishi HMI. SO i have some questions regarding this project 1. While...
1,957
Hi folks, I'm doing a valve positioning system (new plc replacing old discrete instrumentation), the old system has position feedback from valves...
2,667
I have a customer who has requested a keyed 22MM potentiometer on his enclosure to provide speed reference for the VFD. Basically to prevent...
21
4,719
Hello, I would like to install a 1.25k-ohm potentiometer to a 1794-IE8. All I have is a 24VDC source. I noticed that the input ranges from...
2,086
