Power-up Fault on L73 PLC
Robotroc
Sep 2011
Bucharest
46
hello,
I have a question , you met this fault before ? Do you know what are de possible causes for this fault ?
I had 5 PLCs that went in this fault at the same time and i don't know the reason.
My electrician guy tell me that was a 2 power-down cycles a difference of 13 seconds to one another. All the PLCs are in the same LAN network.
We guess that the power-down was the problem but we had more power-down cycles befor and all was ok.
All the plcs battery are ok.
Thank you !
I attach a picture.
You will not be able to resolve this without Rockwell Support.
Make a complete image of SD cards from all controllers and contact your regional technical support.
They will send you additional information that they will need.
Make sure to save complete SD card image.
I would ignore page 19 advice to create power up handler, it does not apply to Type 1 code 62 fault.
Since this is non recoverable fault, it can't be cleared via program.
The only way to decode the actual reason is to get SD card image to Rockwell Support.
when you say SD card you refer exactly to the SD card from SD slot in fornt of the PLC ? , We don't have SD cards mount in it.
Fault code (62) tells me that you have SD card and fault info saved to that SD.
Controller comes with SD by default.
Did you actually open the little door and look?
If you flip the hinged door, you will fine a blue SD card there. Push it with you finger and it will be ejected.
Power flex 527 Network based safety drive had faulty and alarm pop up SOS Code internal fault Unable to set or clear the fault manually or...
137
L81 series processor, DHRIOE 1756 card, communicating to some old PLC 5 IO. Site wide power outage after power up everything is okay except 1...
1,524
All the servo guys out there looking for a little help? I am having issues with a Kinetix 5500 keeps giving me S39 BUS POWER LEAKAGE FAULT. Does...
1,945
Good Day, I do not use Power Flex much and I was called to troubleshoot one at a customer site. So if you have some advice I'd appreciate it...
10,848
I have a controller issue I think. 1756-L63 Using RSL5000 v20.05 I can verify a project and download it, do online edits and monitor fine...
2,810
