JeremyM
Looks like ODVA posted the .EDS for this new family of drives.
https://marketplace.odva.org/products/2432-armor-powerflex-35e?lang=en
Interesting finds:
VendCode = 1;
VendName = "Rockwell Automation - Allen-Bradley";
ProdType = 170;
ProdTypeStr = "PowerFlex TotalFORCE via Embedded EtherNet/IP";
ProdCode = 3;
MajRev = 1;
MinRev = 3;
ProdName = "Armor PowerFlex";
Catalog = "35E...";
New CIP objects/services:
76-byte Input Assembly:
Interesting finds:
- Native 32-bit parameters (some 64-bit).
- 2x Ethernet links (twisted pair M12).
- 1x TCPIP.
- So it's native DLR, no dual-IP.
- Much larger IO assembly.
- Onboard discrete IO.
VendCode = 1;
ProdType = 170;
ProdCode = 3;
MajRev = 1;
MinRev = 3;
Catalog = "35E...";
- 0x37: Expanded CIP file support from 2x static instances: 10x dynamic instances.
- 0x5D: Security
- 0x5E: EtherNet/IP Security
- 0x5F: Certificate Management
- 0x3AC: AB Ingress/Egress (IP / port access rule sets? a soft firewall?)
- Event logging of flavors: config, backup, log, discovery, auth, sys, cipsec.
- SYSLOG format.
- Timestamps to the nanosecond (no indication of CIP Time Sync).
- Security events imply DNS support.
- Logic Status (100: DWORD)
- Output Frequency (101: REAL)
- Output Voltage (102: REAL)
- Output Current (103: REAL)
- Output Power (104: REAL)
- DC Bus Voltage (105: REAL)
- Heatsink Temp (106: REAL)
- Encoder Count (107: DINT)
- Motor Overload Level (108: REAL)
- Trip Fault Code (109: UDINT)
- Current Position (110: UDINT)
- Current Velocity (111: REAL)
- Reserved (112: ULINT)
- Reserved (113: DWORD)
- Reserved (114: REAL)
- Reserved (115: REAL)
- Reserved (116: REAL)
- Reserved (117: REAL)
- Logic Command (200: DWORD)
- Command Velocity (201: REAL)
- Reserved (202: DWORD)
- Reserved (203: REAL)
- Reserved (204: REAL)
- Reserved (205: REAL)
- Reserved (206: REAL)
