Powerflex 4 and 1203-USB
chemdawg
Nov 2012
Milwaukee
31
Hello everyone. Hopefully someone can help me out here. First, I will list what I'm running.
1: Windows XP pro SP3
2: Connected Components Workbench 3.0
3: RSlinx Classic Lite 3.6
4: 1203-USB with 1.004 firmware
5: Powerflex 4 drive
I have been trying for the last several days to connect to this drive, and I have tried everything and everything. No luck. I flashed the 1203 through hyperterminal, with the latest firmware, with no luck. I setup the driver in rslinx according to the instructions provided in the AB 1203 manual. It does not matter what I do. I cannot get a connection to the drive. Is there something I'm missing here?
Any help would be highly appreciated. Thanks
Pat
I have used drive executive to connect to the pf4 after setting up rslinx , make sure your using the right com port when your setting up Linx
...make sure you're using the right com port when you're setting up Linda
Is that Linda Linx, the wicked linx of the West, or Glenda Linx, the good linx of the East that connects with a wink and a smile? :confused:
Is anyone else having looooong connecting times when using CCW to a 750 via a 1203-USB? It is taking upto 10 minutes to connect to drive or...
1,789
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
173
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
276
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
176
