powerflex 400/40 modbus communication
shadababe04
May 2015
new delhi
how can i communicate with powerflex 400/40 through arduino with the help of modbus rtu/tcp.
what is modbus register mapping of powerflex 400?
RTFM!
Please see attached Rockwell documents. Don't forget the offset when addressing Modbus (n+1).
Hope this helps.
Rob
Hello I am a newbie so apologies in advance if I am not making sense or miss important information. I am trying to setup a PID Loop on a...
6,280
Hello, all I am hooked from an idec PLC to PF 400 Drive and need to read and write data via modbus rtu over rs485 I got it all hooked up correctly...
6,333
Hi All My issue is with an MSG error code 37 - 'Message timed out in local processor' between an ML1400 and 8 Powerflex 4M's. When the VSD's are...
8,925
Evening all, Can someone please tell me (i know the manuals say it is possible), if MicroLogix 1400 PLC will communicate thru 1763-NC01 cable to a...
8,555
Hello I have a powerflex 400 of 25HP for a 60amp 25HP motor, the motor have a belt that move the clarifier of milk. It is a process that requires...
4,201
