stretch_af
Bear with me for a moment. So an issue came up this morning, one of our pumps wasn't running. I plug into the processor (5069 ver 31), the PowerFlex 525 (communicating via Embedded Ethernet) is being sent a speed command of 6 HZ, but isn't running (yes, 6 HZ, not my design). I right click on the drive in the project tree and select properties, but I get a Path Spicing error and can't see it's parameters. Off line I can see the parameters. I open RSLinx, I can see the drive in my Ethernet/IP driver but I can't get to device properties. I can't even see the drive over the more generic Ethernet driver. I use the 1203-USB and connect to the DSI port on the drive and successfully connect and go online with the drive with CCW. By this time the drive fixes itself and is working properly and is doing what the PLC tells it to.
So right now, our system is working, but I still can't connect to the drive over Ethernet and its bugging me.
Thoughts? Comments? Confused?
Justin
Justin
