Powerflex 525 control voltage 18 VAC
heather.banks
Dec 2022
Indiana
Hello All,
I am working with a powerflex 525 trying to get multiple speed references. I got it working on my bench and then I went out to the field only to find that the control voltage running the drive is 18 VAC. I can't seem to figure out where the 18 VAC is originating from. The drive start, stop, reverse, ect. is all controlled off of 18 VAC. I did not even think that it would work in this fashion. I was hoping someone could shed some light on this.
So there are relays that pass the 18VAC we are using in the cabinet. The relay contacts on the drive measure 120 VAC. I don't see where we are going from 120 VAC to 18 VAC (it would be nice if we had electrical schematics for said machine). It almost seems like it has been wired wrong and something is shorting out and pulling down the voltage. In theory if we are using 18 VAC to start and stop the drive there should be some sort of device that changes that voltage right? Also terminals 11 and terminals 1 are still jumped together causing even more confusion. Terminal 11 is + 24 VDC correct? I really don't understand how these drives even start and stop properly.
Two thoughts come to mind.
1. The 24v dc has bad capacitors so in effect you have rectified ac, a typical 24 v psu will give a reading of about that voltage, had one where a air blowing bottle line buildback was not working, the buildback was on a sensor plus timer, although monitoring the PLC the input showed true, the timer did not seem to time out, mesured the 24v DC supply & it was about 18 v in dc mode so thought it might need adjusting but could not as the adjustment pot was at full, I then noticed the Input card led's seem to be rather dim, checked with a scope & it was rectified AC i.e. pulsing at 100hz as the capacitors had completely dried out.
2. pickup of AC induced voltage, probably not as I would expect the DC side to be higher, but you never know.
So our Powerflex 525's are set up to allow REMOTE operation from PLC through network. But if network is lost we want to be able to run in LOCAL...
570
Hi, I'm looking to see if there is a solution for an application I'm attempting. I have a PF525 running a pump. It is primarily hard-wired...
1,540
Quick question for all. Looking at upgrading my plants VFD's to PF525 however all the current plant controls are 120VAC. Can the PF 525 be...
3,782
Hi All. I am trying to commission a Powerflex 525 Drive but currently only have access to +24VDC, I simply want to assign Ethernet/IP Address...
18
7,765
we have a powerflex 525 speed reference 1 set to 0-10 v input and speed reference 2 set to ethernet ip but when enabled in the program the drive...
3,683
