Hello, I recently replaced a power flex 525 drive which has identical parameters and is controlled via a logix 5573 controller.
I have run into a snag being the drive running the motor is going the wrong direction which is hooked up to a pump.
I have swapped phases around and the motor still continues to run the wrong direction.
Is there a parameter in the drive I can change or does this need to be done via the plc?
I have an engineer who is going to login and change if possible via the plc but if we can't eliminate it via the touch pad that would be a better solution.
Is it controlled over Ethernet also.
