Powerflex 525 drive.
Prayder
Jun 2014
Arkansas
254
Question....We have a new Powerflex 525 drive that we have set some parameters in but every time it is powered down and brought back up the parameters have been reset back to the default. We have other powerflex 525 drives that don't do this so I was wondering does anyone know of a setting or something I might be missing? I don't remember one..
If it is being controlled by a controllogix processor, make sure that "ADC" is not enabled in the drive configuration of the CLX program. "ADC" (automatic device configuration) would do exactly as you are describing.
That seems to have worked... Thank you!!!
Hi all, I have a powerflex 525 where there is no voltage coming out to the motor. The drive was reset to factory defaults with stop and saftey...
2,818
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,449
Hi I have a powerflex 525 that is connected on ethernet to a compactlogix and is on ADC , I have just changed a setting on the drive and if I...
1,832
I have a machine with a CompactLogix ver20 and PowerFlex 40 multi drive node. That PF40 has a Comm-E ethernet adapter and has four PowerFlex-4Ms...
1,893
So we replaced a PowerFlex 525 drive with the exact same model. I was told that once it is in and given the old IP address, you can upload the old...
24
14,399
