Powerflex 525 Drive
Solved this issue. There is a parameter to enable Reverse direction that I was not aware of. This code works as shown as long as my Drive:O.Start is true. Direction is selected by toggling Debug_Bits_SM.31.
Welcome to the forum, duskogavrovski!
Since this thread is two years old and your question isn't directly related to the OP, I'd suggest you start a new topic to get better results.
Hi all, I have a powerflex 525 where there is no voltage coming out to the motor. The drive was reset to factory defaults with stop and saftey...
2,774
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,431
Hi I have a powerflex 525 that is connected on ethernet to a compactlogix and is on ADC , I have just changed a setting on the drive and if I...
1,822
I have a machine with a CompactLogix ver20 and PowerFlex 40 multi drive node. That PF40 has a Comm-E ethernet adapter and has four PowerFlex-4Ms...
1,888
So we replaced a PowerFlex 525 drive with the exact same model. I was told that once it is in and given the old IP address, you can upload the old...
24
14,314
