Powerflex 525 driving a flywheel
joseph_e2
Dec 2010
Harrisonburg, VA
1,093
We have a handful of nearly identical flywheel-driven machines. About a year ago, we installed a 15HP Powerflex 525 drive in simple V/Hz mode with DB resistors on one of the machines. It's been running great for that whole time.
We have it set up so the STOP input (terminal 1) is wired through the DB resistor thermostats, input 2 is Run FWD ,and input 3 is Run REV. Since it's replacing an across-the-line reversing starter that's in the midst of a bunch of hard-wired relay logic, the drive's output Relay 1 is Ready/fault and will cause the relays that control drive inputs 2 and 3 to drop if the drive faults. This arrangement has been running fine on machine #1 for over a year.
We tried to duplicate that installation on another machine that has an almost identical motor (np is 1765 RPM instead of 1775, but otherwise the same including NEMA Design) but we're getting DC Bus overvoltage faults after the machine cycles for around 10 minutes. When trending in CCW, I see that the output frequency drops to 0 from one sample to the next while the STOP and Run FWD inputs are still ON and Relay 1 still indicates OK. The commanded frequency doesn't change. On the next sample, Relay 1 drops out, which also drops out input 2 (Run FWD). Then, about 400 ms later, the DC bus climbs past 810V and the drive faults on bus overvoltage. That's the only fault that's shown on the drive. The only parameter differences between the 2 machines are the network addresses and the v7 drive has flying start enabled since it doesn't have a flywheel brake that applies when the motor is stopped.
The first attachment (..._FreqDrop) shows the values of the trended parameters as the output frequency drops. The second attachment (..._NextSample) shows the next trend sample, at which point Relay 1 has dropped, taking Run FWD with it. At this point, the DC bus (the visible graph) is still well within its normal range. It trips at 810VDC, which happens about 400ms after the output frequency drops.
Per a suggestion from Rockwell, switching the drive to SVC (with a static autotune) accelerated the issue and I actually saw the STOP input open when the resistors got hot. The fault happened a lot sooner (in a few minutes of cycling instead of about 10 minutes). They also suggested changing p36 to 1800 to remove slip compensation and then to use P531 to disable the bus regulator, but neither improved the situation.
In case we managed to get a bad drive out of the box (or broke something during installation), we swapped in another brand new drive and got the same result. The only difference between the drive that's working fine and the ones that are faulting is the firmware version. The older one is v6.001 while newer ones are v7.001. The release notes don't highlight any issues. I would rather not flash the firmware down, but that's about my last option that I see here.
Any ideas?
I'd verify the number of poles on both motors. I had this exact issue when we were spinning a 2500lb load and the issue ended up being the original motor was marked as a 4 pole but it was rebuilt as a 6 pole. Once we swapped to the 4 pole, it worked without issue.
Based on the output speed of the machines, the motor speeds seem to match the nameplates, which are 10RPM apart. The first motor may have been a re-wind, but I'm 80% sure the 2nd is brand new. Regardless, they are about 5Hz apart for the same machine speed, which is consistent with the results we got measuring machine speed with across-the-line starters.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
235
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
475
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
234
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
299
