Baker in Virginia
Good Afternoon ,
I am getting ready to refurbish 2 machines . It will have 3 SEW gearmotors on each machine. I would like to keep the selected speed very consistant with what speed is selected. I was going to use encoders , but to reduce cost , I was thinking of going with the option that was discussed on an earlier thread , Open Loop Vector Control. What I would like to do is have the operator select recipes of products they run . In these recipes , will be the speed that these 3 motors run in RPM. In the Compactlogix I will figure out what speed the motors will run according to the RPM setting.
My question is , other than using encoders , what is the best way to keep a constant speed on these motors. I imagine there is alot of factors that cause a motor to slow down and speed up , correct ? If I would go with the Open Loop Vector Control , how would I start setting that up. I imagine Autotuning would be a start , correct ? I tried to find some technotes , but really only found brochures concening the PowerFlex 525 and it's options.
Would you folks have any infornation that will point me in the right direction. Also , if you believe I am approaching this the wrong way , let me know.
Thanks so much in advance.
