PowerFlex 525 Multidrop Version Mismatch
Oct 2015
Melbourne
23
Hi All.
I have a compact Logix project where I am adding Powerflex 525 drives in a multidrop configuration.
The modules added to the Ethernet are PowerFlex 525-EENET-Multi.
They are 0.5hp, rev5
All works fine.
I am now adding the same thing except it is a 5.0hp version.
When I select 3P 460V 5HP in the drop down rev2 is the only one available? But the drive is a Rev5.
"Match Drive" produces a Version Mismatch error
I can't find an EDS file to add to the available profiles on the (unhelpful) Rockwell site.
I tried the "Create Database" option from within Logix Designer as suggested, it links, and does what it should, but I cannot find where it puts the info nor how to install it?
Any help appreciated.
Try opening RSLinxs and see if you can get to the drive and right click and download the EDS file from the device. (I think PF525 should work.)
Thanks,
Good idea. I just tried, got the EDS file imported it to the project. Ended up with same issue.
Rev 5 for 0.5hp.
Rev 2 for all others...
Unfortunately I'm remote connecting and not on site. I have a partner there that can run around and check/adjust. But not with PC access.
Thanks for the help, appreciated. I'll keep searching.
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
235
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
246
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
475
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
232
Hey all, I am currently working on a depalletizer for a customer and we are doing a hoist upgrade. This is a SLC500 processor and the drives are...
297
