Powerflex 525 over EIP not starting
Topwater
Jan 2012
Ontario
Hey All.
I've got a Powerflex 535 v1.005 in operation here and we are having intermittent issues with it being given the .Start command over Ethernet and it not starting. So far the only 'fix' is to cycle power on the drive.
I understand that it's very old firmware, and I plan on upgrading as soon as we get some time but I was wondering in the meantime if anyone has seen this before with these drives? Is it a similar issue with the .stop and .start being on at the same time that's causing a problem?
In this line there are 3 or 4 other conveyors that stop and start quite frequently that do not have this problem and the start/stop code is the same.
Thanks,
Adam
91
88
259
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
267
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
492
