Powerflex 525 Ready bit goes off
bornwild
May 2010
Riyadh
429
I have Powerflex 525 with EIP interface where to ready bit goes off for some reason and the drive dont run. Things I have checked
1 Parameter T105 is set to fault enable. So If I have a issue with safeties i should be getting a fault 059 but when i check there is no fault on the drive
Stop command is issued only if the drive is active so i dont have a issue of race condition.
The only way to start is reset the safeties and drive ready bit goes 1. It is strange .
Good Afternoon , I have several new PowerFlex 525 drives. 5 drives out of 17 will start thru my Compactlogix start signal . The rest will...
19
16,192
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
236
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
247
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
480
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
238
