Powerflex 525 - What would be the best way to reverse in RS Logix 5000
Aug 2016
Virginia
343
Good Evening ,
What would be the best way to reverse a motor using a Powerflex 525 drive in RS Logix 5000 ? The drive is running in one direction , but would like to reverse it, I'm using Ethernet and a CompactLogix . I took notice that the Forward and Reverse in the the outputs for forward and reverse are 0 , but it is still running . I took notice that the input from the drives for "Actual" direction is 1 . Would I force a 1 in the Forward or Reverse ?
Thanks for your help ,
put a 1 in ??:O.Reverse and it will go in reverse
to get it to go forward again you will need to take the 1 out of ??:O.Reverse and put a 1 into ??:O.Forward.
Alan
?? = your tagname
Hello, I'm hoping someone can help me with understanding how to set/change these data types. We recently swapped from Invertek to AB drives...
81
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
79
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
253
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
263
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
489
