Powerflex 700 Display and leds flash when power is removed
M1WC316
Dec 2010
Illinois
Hey I was wondering if any one has had this problem before,
I powered down a Powerflex 700 and the Display and leds flash and keep flashing. The drive has been powered of for 24 hours now and its still flashing.
I am using a 110 v input card. which still has power. Tried pulling it off still flashes. have not checked to see if I have any back feed voltage.
Did you call AB Tech support? You don't need a TechConnect contract for help with VFDs. If you wait until after hours, you leave a message and someone calls you back within the hour, but if you call during the work day, you usually get right through (after you navigate through the automated phone tree)
(262) 512-8176
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
195
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
149
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
370
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a...
493
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,203
