Powerflex 700 VC Fault Clear using dig input and pushbutton
Jasondelane
Mar 2015
Florence sc
221
I've set up a powerflex 700 with Digital Input 1 (set to Stop - CF), and wired a pushbutton to give the input to clear faults. I've verified that the input is being received by monitoring the digital inputs on the him. I tested it by cutting power to the drive just long enough to get an undervoltage fault, but when I push the button, the fault doesn't clear. I've also tried setting Digital Input 1 to Clear Faults, still no luck. All other inputs except #6 are set to "not used", since I'm using 6 as an Enable.
Is there something I'm missing? Using the stop button on the HIM clears the fault fine.
Nevermind I figured it out. I had all my Masks set for Port 5 with digital inputs masked. I fixed the mask for digital inputs. Thanks for reading though. :)
Hi , I have an Allen Bradley Powerflex 700 Inverter It has a green power light ( led ) and under that has a status Light ( led ) The...
2,252
Hi all, i have a powerflex 700 Alen Bradley drive. I recently got a fault on the drive. I am not familiar with these units and wanted to ask...
2,081
Running a Powerflex 700 VC 40, two 10 hp motors in parallel with their own overcurrent protection, FVC mode, Intertia autotune done, external...
7,049
I have a Powerflex 753 that shows a fault code "212 safety jumper out" upon powerup of the vfd. The jumper is in place and there is the same fault...
5,181
Good Morning , We had 3 PowerFlex 700( Water-cooled ) Cat. No. 20LD360N3NNNAN20WA 300 HP drives fault out at the same time. We were able to...
5,678
