PowerFlex 700
You can also change P102 to 60Hz. It is likely set at 10Hz and that would be the command it would get (if Dig In 5 was true) but would not go below 12Hz if that is your minimum speed setting.
I am a bit confused that when my motor runs on network through DPI port 5 where it gets the speed signal.
My understanding that when runs on DPI port 5 (Parameter# 93 = 22)motor gets the control command and goes to Preset speed 1 selection and if I need to control from terminal blocks than I need preset speed selection 1 to 7(parameter#101 to 107)
From your settings:
Parameter# 90= DPI Port 1 value=18
Parameter# 91= DPI Port 5 value=22
Your speed reference is coming from the local HIM. (DPI port 1)
and oddly, your ControlNet is adjusting the maximum speed for an analog speed command input.
Did you try my suggestions? What is the result?
I didn't get an approval from production to do any changes. Last night we put back to Auto from BAS and so far NO dropping speed.
We have an upcoming shutdown during Christmas and at that time we will do all tests.
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
169
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
138
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
365
Hello all, I was forced to replace a Powerflex 700 to a Powerflex 70 due to what is available. The digital input parameters (361-366) have a...
486
Hello, I have an existing application that has a Powerflex 700 with a 20-COMM-E adapter controlled by a Micrologix 1100 via Ethernet. The setup...
1,195
