Powerflex-755 EENET Port-8 IO Module
prakasha
Dec 2022
Davangere, Karnataka, India
75
Hi All,
We are trying to commissioning Power flex 755 embedded(EENET) with Port 8 115V IO module mounted. It is communicating but IO module Inputs are not updating what could be the issue. Tomorrow we will be taking trail Please suggest me what could be the issue..
If you’re not using CCW, I suggest using that. When adding the drive to the project, take the time to add any peripherals to the installed ports, including the 115V IO module and any HIM to the defined drive. Maybe using discover will find the peripherals, I'm not sure. I found the startup wizard to work well from CCW to define start sources and other details.
So I've been looking at the documentation, and I'm a bit uncertain about the data for the AOPs on these AB drives in general. I don't have the...
1,273
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
280
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
182
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
143
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
229
