PowerFlex 755 -No movement when commissioning direction test and auto tune?
Rob S.
Sep 2008
Maryland
739
Good Afternoon ,
I am commissioning a PowerFlex 755 , and I entered the motor data. I am at the stage of "Motor Test" direction test and auto tune. I cannot get any motor movement. What could be the cause ?
Thanks so much.
What current is the motor pulling during the test? Are you sure motor wiring is correct? Is there a contactor or disconnect after the drive?
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
194
So I'm replacing a terminal block on the inverter board for a 755. I'm wondering if anyone knows what conformal coating would be best? I'm not...
152
Powerflex 755, running 2 weeks, and faulting with code 17 input phase loss.
239
Hi All, This is my first PowerFlex 755 drive setup and I am having an issue with when I start the drive it runs at my minimum speed 5Hz, but...
458
