PowerFlex400 with CompactL L32E comms ERROR
jorgeGal
Jan 2008
Lima
22
Hi, I have this configuration and I´m receiving 203 (timed out) error from the I/O tree in RSL5000. Although, I can read parameters from the drive. I tried changing the RPI parameter, from 20ms to 30ms with no results.
The VFD is connected by a wireless network to the PLC. I have unmanaged switchs in both sides.
Where should I start to check this issue?
First, try increasing the RPI to a relatively large value, like 200 ms.
Unless you have a very good reason to use a wireless IP network, I strongly recommend against it.
I've read a bunch of the post on here as far as communicating between the ML1400 Channel 0 and the Powerflex 400 via RS485. I cannot for the life...
1,867
Hello I want to set up a communication through GSM or LTE from a PowerFlex drive and other instruments (flowmeter, level meter, etc.) to PC 100...
885
Hi!, I have 4 powerflex 400 recently installed and my customer is asking me if I can set the drive up to rearm automatically after a power fail. I...
1,614
Hi, I have a PFlex 400 networked with Dnet over 22-COMM-D as well as a 22-HIM-A3 on panel front. I am using the drive from remote as PID...
2,740
Recently I was called into a plant as a consultant on a machine that was experiencing a large number of drive failures. All eight failures were...
2,492
