ML1400 to Powerflex400 RS485 Help
Jason Ozolins
Mar 2012
Fife Lake, MI
59
I've read a bunch of the post on here as far as communicating between the ML1400 Channel 0 and the Powerflex 400 via RS485. I cannot for the life of me get it to work properly. I am using the 1763-NC01 connector. Right now I have A/B connected to pins 4/5 on the RJ45. I have tried swapping, and think I have the right config as when I swap one way, the Port LED flashes red, and clears to Green the opposite config. I have channel 0 in the PLC set up correctly as No Handshaking (485) and I get no response when sending a msg. I have confirmed comms rate & node address.
Terminal 20 on the VFD is connected to ground... and I missing something on the NC01? I have tried with a jumper in COM to CGND and without.
Thanks for any advice.
Attached is how I have the NC01 Wired. TERM & A Jumpered, SHLD & CGND jumpered. I have A going to Pin 5 of RJ45 and B going to Pin 4 of RJ45, and SHLD going to Terminal 20 on Powerflex Board.
I didn't have any 120 ohm resistors so I had to put 4 33 ohm in series to get close to 120. I have C102-107 configured properly as well. Do I need 120 ohm resistor on the NC01? Thought jumping to TERM took care of that. I appreciate every and any suggestion. All I want to do is write to speed reference but get zero response from VFD. I know the cable/NC01 works because I communicated with a modscan to the PLC thru my computer and USB 485 converter.
I don't think resistor would be a problem in short wire jumps and NC01 has built in for that end.
It is +1 addressing tho, so maybe look at that. How are messages set up?
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
502
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,448
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,228
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,832
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
843
