powerflex4m drive communication with slc503
victorrunPLC
Sep 2010
Ontario
what cable and what module do I need to have the powerflex4m drive communication with slc503, I now have 22-scm-232 and 22-RJ45CBL-C20 CABLE, Does anyone know an economic solution, thanks
You will need an RS-232 port on your computer.
Almost no modern PCs have these built in. I prefer a USB/RS-232 converter made by Keyspan/Tripp-Lite, the USA-19HS.
It's a few bucks more expensive than the cheap devices on the market, but the utility included with it and the overall stability have saved me thousands of dollars in time and hassle.
It's compatible with most A-B and other RS-232 based protocols and devices except for Data Highway 485 (which needs a special purpose protocol converter, the 1747-UIC).
HI I have 2 pf4m drives connected on modbus to my micro1100 all is working fine although i have noticed one thing.If you turn off the first drive...
2,917
Hi all. I have Powerflex 4m, i read a manual and find out that it support Modbus RTU via RS485. I try to communicate with it, but I have no...
2,034
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
217
Im trying to install a Siemens upgrade license using Automation License Manager v6.0. I clicked D: mistakedly, and now I can not find a way to...
53
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
48
