Powerflex70 series A test bench
Compass
Feb 2015
Goderich
101
We have a Allen Bradley, Powerflex70 series A drive. We would like to use it as a test bench and programming station for communication modules. (At least until we need to replace a drive somewhere).
It's a 600 Volt drive. My boss asked me to find out if it can use lower voltage for purely programming applications.
This is one of those tricky problems where if it can the manual would probably brag about it, but if it can't then I just won't find mention anywhere and be left wondering and uncertain.
Could somebody please just tell me yes or no, and maybe point to a reference.
Most drives can power up on lower voltages/single phases, look for a "derating" in the manual. This will indicate that if you use a lower voltage, the drive HP rating drops by a certain amount. Since you just want to power up the control it really doesn't matter.
I've used a 120V --> 220VAC/480 xformer and powered up drives for testing.
That drive powers its PC boards direct from the DC bus, so the input voltage must be at the stated minimum supply, otherwise the drive shuts itself down. For a 600V drive, I believe that MINIMUM is something around 375VAC. It's in the manual.
Just checked, it's 345VAC.
Hey folks. Quick question about direction control on a PF70. The control is all over the connection on the 20-COMM-E. Start, Stop, Speed...
2,115
I need to add a couple of older PF70 drives to an application using PlantPAX, the 750 series have a fault list code in the library, but not the...
1,622
I have an issue with a Powerflex70 drive communicating with a PLC5. The drive is setup as 1/2 rack and is communicating over remote I/O. It is...
1,828
hi we have a controlNet network with a PLC 5555 and several PowerFlex70 that are networked via COM C network adapters. Recently one of the...
1,260
please i want to know to transfer the paramater value from powerflex70 to another powerflex70 with HIM please reply for me
1,487
