PowerFlex755 no torque
a062549
Feb 2012
Home
139
I am trying to startup a PF755 with a 400hp motor.
I did the startup wizard and all the auto tunes with the motor uncoupled. It runs and follows speed when uncoupled fine. It has one DI card for giving a "permissive" signal.
When it's coupled and I reference say 30 Hz, the motor spins as it should until it runs into the current limit. Speed stops at 25 Hz, and then when the amps start to come down it tries to speed up to speed setpoint. The motor can be turned hand while coupled, freely turns.
Uncoupled the motor is using a max of 110 amps, works like a charm.
I have the same drive model running two other 350 hp drives with no problems. Have verified the motor wired correctly, and compared the setup to the other drives.
The drive is doing all that it should be as it tries to boost speed but shuts down on current limit. As it should...
The low torque, with exceptionally high amperage has me scratching my head.
Would that be energy saving mode?
Not sure what your voltage in China is, here in the US our volts to Hz ratio is 7.666 volts to the Hz. When you are experiencing the problem, check your output volts against the amps. If it's considerably below your volts to hz ratio you need to not use the energy saving startup wizard.
Sounds as though you have inadvertently set a torque limit in programming. Uncoupled, the motor can get to 110A because that is mostly reactive current, not torque producing current, the drive will know the difference if you are in any kind of Vector mode. So under load, the torque producing current is hitting that limit and overriding your speed command, which is exactly what it is supposed to do. I don't have my manual here to look, but there is a parameter for torque limit, check the value you have it set for.
Update!
So the AB Service person comes by to look at the drive issue.
He says, "Oh, its in Param 35, it sould be Induction SE, not V/Hz. And not pump/fan!
I replied "but it is a pump"(?) :mad:
We changed it to Sensorless Enhanced and Custom vhz, Paramerters 35 & 65. BANG it works as it should...
We changed the others to the custom v/Hz too. All good now.
Thanks for the replies!!
J
Just wondering if anyone can send me a simplified Torque setup for a 40HP Allen Bradley 755 Powerflex drive. I worked all day manipulating what a...
2,911
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
401
powerflex755,,,, I set ptp as per page 128 of this document, but the motor does not work. I try to control using Absolute Encoder. Please let me...
1,582
Connect the powerflex755 to the encoder motor, and try to control the speed over Ethernet. The speed reference and communication port settings...
2,037
I replaced a couple of 1336 Plus II drives with PowerFlex755 drives on my DeviceNet Network. The drives are functioning fine on the network but...
1,772
