You can use any output card you want. You just need a relay with the coil voltage to match the output of your PLC. Then the 240 volts goes through the relay contacts.
True. A Click CO-04TRS will switch 250v at a maximum of 7A. I just always feel better putting anything more than a solenoid or relay coil through an interposing relay.
