Powering 240VAC device from PLC
Newbie2016
Oct 2016
Australia
If I am starting a 240VAC device from a digital output, will i need a 240VAC DO card and a 240VAC relay?
Or is there another way to achieve it?
You can use any output card you want. You just need a relay with the coil voltage to match the output of your PLC. Then the 240 volts goes through the relay contacts.
There are PLC's that have relay outputs that can switch that voltage, but it will depend on the power the device needs.
For instance a S7-1200 plc can switch 250v, but only for a max of 200watts.
True. A Click CO-04TRS will switch 250v at a maximum of 7A. I just always feel better putting anything more than a solenoid or relay coil through an interposing relay.
Yeah I'm definitely with you on that. I generally don't use relay out's unless I absolutely have to.
Is it possible to set IP address of Powerflex drive, without powering up the entire 3 phase circuit? Is there some way to just power up the keypad...
727
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
568
Anyone ever attempted to power up and test a plc2 or plc5 communication card or otherwise using a power supply attached to the PCB edge? I haven't...
1,394
Hi All, We have a HMI at work that uses a AxiomTek CAPA841/842 SBC, and it has recently stopped working. We've tried replacing the RAM and SSD...
626
Hey everyone, Posting this for my boss who's onsite installing a replacement PowerFlex 700 after another one failed yesterday. Looks like one of...
2,067
