Powerflex set IP without powering up entire drive
A_G
Jul 2014
MA
370
Is it possible to set IP address of Powerflex drive, without powering up the entire 3 phase circuit? Is there some way to just power up the keypad using 24 VDC or something? The actual motor is not hooked up to the drive yet. I want to set the IP of the drive so that I can add it to the Studio5000 PLC program logic . I don't know when the motor will be ready to be wired to the drive circuit
Thanks in advance for any advice! I havent worked with drives in a while and I'm rusty
With that model, you can take the control module off and plug a USB cable into the back of the control module. you then go to my computer or this PC depending on operating system, it will show up as a drive, open that up and there will be an executable that you can run to upload the drives parameters, once you have uploaded the parameters you will have a .pf5 file which you can open/import into CCW, after setting the IP address you will need to save the file (I usually save with a different name) and then download the file back into the control module, don't shut down the upload/download program whilst you are making the changes.
Hello, Would anyone happen to know what parameter in a PowerFlex 525 to have the drive trip if the torque permissive set point is exceeded...
445
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
595
I have a refurbished PowerFlex 4M that I am trying to re-use. The keypad is locked out, I cannot go to anything other than d001. I do not have...
847
Good Evening , I’m trying to get our maintenance staff to set the IP Address for a 22-Comm-E card for PowerFlex 40 drive . I usually use...
2,387
Good Afternoon , I'm sorry , but here is another one. I have the PowerFlex 525 speed reference set to Ethernet / IP and it is running at 60...
6,249
