PowerFlex 4M reset program?
bigsteve
Aug 2020
Memphis area
30
I have a refurbished PowerFlex 4M that I am trying to re-use. The keypad is locked out, I cannot go to anything other than d001. I do not have the 1203-USB cable to connect it to my CCW software, and that cable is apparently sold out unless I want to spend big bucks on a used one on ebay.
Is there any way to manually force the drive to erase its program, e.g a keypress or jumper combination or something inside the unit?
The keypad cannot be locked to view parameters or navigate. There are some parameters you can't change if the drive is running though.
I'm afraid the keypad requires further repair.
The rest you surely know, set parameter A458 to "0" to unlock and P112 to "1" to reset to default.
Regarding the cable, sorry, can't help
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
608
Good Afternoon , Powerflex 753 seems confusing just to configure a input. A coworker installed a pushbutton to use as a fault reset for a...
4,013
Hi, people I have a problem with the reset encoder routine. I can not reset encoder positions(parameters 376 and 377). I followed the manual and...
3,127
is there anyway to discharge the capacitor without waiting the 3 mins to reset the drive? :wait:
2,488
Hi, I need some help on how to reset fault on the Powerflex 750 via ladder logic. I have looked through the parameter documentation and I...
9,627
