Powerflex 525 reset encoder
janasamara
May 2017
Portugal
20
Hi, people I have a problem with the reset encoder routine.
I can not reset encoder positions(parameters 376 and 377).
I followed the manual and tried to do the automatic startup routine but it does not work.
First through a plc input I try to activate drive input 7. At input 8 of the inverter I have physically attached a wire to the sensor. I also have parameter t67 set to "35 Find Home" and parameter t68 set to "34 Home limit".
I do not know what I might be doing wrong.
Can someone help me by doing?
thanks
Can someone help me ?
thanks
Hi All, I am working on testing a project with a Powerflex 525, final project will be a 755, and I am trying to reset the Elapsed kWh meter over...
600
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
238
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
248
New to vfds. I put in parameters. IP, but I get ethernet flashing and link solid. What did I do wrong?
484
Are the N files in the 525 the same as the 40p for ethernet? (E-Comm card) I have used 40P with Micrologix 1400 Messaging but don't see the N...
242
