I think what he is talking about is powering down the drives, and having to wait for the full discharge of the bus before restoring power.
If you cut the time really short, you risk drive damage and nuisance faults since the DC Bus low faults will not have been cleared by a proper power up sequence.
3 minutes is probably some rule of thumb. Put your cat 3 meter on DC and measure the DC bus. When it drops below 20 or so, you are good to go to work on it. You will find some drives power down quite quickly depending on what they are doing and how they are programmed.
If you cut the time a little bit short, you may risk some drive damage, but those are disposable drives anyway, don't use the built in power supply if you can help it, and keep a spare or two handy.
I have used the safe off option with the PF70 series so you might step up to that model if your application suits it (safe off) and it accomplishes your desire (uptime) with a reasonable payback.
My understanding of Safe-Off, is that it is a monitored force guided relay hardwired into the IGBT gate signals or something to the effect, and can be part of a category 3 system.
When I have it my way, for MCR and e-stops, I like to keep the drives powered and use contactors between the VFD and the motors. wire the enable (coast input) through an auxiliary contact, and let the safety circuit open those many contactors instead of power cycling all those expensive drives. Many people will say that this is bad for the drive, but as long as you shut it down first or simultaneously and close the contacts (reset the safety circuit) before commanding it to run again, the drive will be just fine and happy not having to faint out and be reawakened every time an operator needs to tweak an adjustment inside a door.
