Powering Down The PLC
Aabeck
Feb 2013
Detroit
1,860
Just came across a second panel this month where the PLC lost it's program due to a low battery & the power being dropped. On both machines the PLC was (keyword = WAS) powered by MCR power, not line power (I rectified that situation while I replaced the battery & reinstalled the program I had a copy of). I have never done this, as I figure the PLC should be on whenever the service disconnect is on, just use MCR power to supply most outputs, leaving some outputs line powered (Red stacklight, MCR enable relay, Buzzer, etc. but never any process items) with the PLC monitoring if MCR power is on. Also, this PLC had MCR power wired to an input & did check if it was on to run things, but if MCR power was off the PLC would be off.
What is the reason, if one, anyone would wire a PLC to MCR power?
Am I alone in this thought?
I once ran into the exact same problem on a small conveyor system. That was caused by "BIL Syndrome" - the control panel was built by the plant manager's brother-in-law!
Is it possible to set IP address of Powerflex drive, without powering up the entire 3 phase circuit? Is there some way to just power up the keypad...
723
hi every one is t possible to power the (6SL3244-0BB12-1FA0) CU240E-2 PN unit with an external power supply 24vdc without the need of the power...
564
Anyone ever attempted to power up and test a plc2 or plc5 communication card or otherwise using a power supply attached to the PCB edge? I haven't...
1,384
Hi All, We have a HMI at work that uses a AxiomTek CAPA841/842 SBC, and it has recently stopped working. We've tried replacing the RAM and SSD...
624
Hey everyone, Posting this for my boss who's onsite installing a replacement PowerFlex 700 after another one failed yesterday. Looks like one of...
2,053
