PR Electronics 3109
Joel201
Nov 2013
Calamba City
151
Good Day,
I need help in regards of using a PR electronics 3109 signal splitter. I need to split a 2 wire 4-20mA signal from a transmitter. Anyone can confirm if i should use the 4-20mA loop as setting for my splitter and anyone can give me a wiring diagram. Thanks in advance
Regards,
Joel
Heres the wiring sorry for the poor drawing hehehehe... i am just confused becasue if i will connect the two wire transmitter to the splitter will it create two 24 vdc power supply because the splitter has it's own power supply terminals thanks again
Hello, all! I'm on the cross-roads between applying for the: PE in Controls Systems - https://ncees.org/engineering/pe/control-systems/ and PE in...
3,790
let's say I am developing my own PLC. I have schematics and I want to pass to PCB production. But I am new in electronics and I need to check my...
1,874
Hi, Does anyone have any experience with hydraulic fluid static electricity affecting electronics?
1,782
Hi All, i know technically not a PLC, but you guys have a wealth of knowledge that maybe someone will be able to help in this subject. i have an...
1,430
Could any one explain me regarding the EDS file of a devicenet device. I am trying to understand. My question is Input 1 : it says it should be 8...
1,563
