Question regarding Electronics Data Sheet
arocon
Oct 2006
Dubai
171
Could any one explain me regarding the EDS file of a devicenet device. I am trying to understand. My question is Input 1 : it says it should be 8 bytes, is it correct or not ? what is 64 ? what is 3 (path size) and what is symbolic path ?
But Input 2 : why it is 36 bytes though it is written 1.
$ $$$ Input Connections $$$$
Input1 =
8, $ 8 bytes
64, $ 64 bits are significant
0x0001, $ Poll
"Assembly 100, Parameter Based", $ Name String
3, $ Path Size
"62 36 34", $ Symbolic Path for Assy instance 100
"Contents determined by Parameters"; $ Help string
Input2 =
1, $ 36 bytes
1, $ 288 bits are significant
0x0001, $ Poll
"Input Assembly 50", $ Name String
3, $ Path Size
"62 33 32", $ Symbolic Path for Assy instance 150
"Bit 0 - Fault Status"; $ Help string
Really appreciate if anyone please explain me those ,
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,028
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,122
Hello, I have a question regarding the analog output modules on a AB Micro850. I'm not getting an output to my valve and when I put a meter on it...
1,540
Happy new year everyone. This is more of a Electrical engineering question than a PLC one. Can a Motor and a VFD that is rated for 240/480...
29
9,992
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,102
