Question regarding Micro850 Analog Output Module
MudShark
May 2017
Oklahoma
Hello,
I have a question regarding the analog output modules on a AB Micro850.
I'm not getting an output to my valve and when I put a meter on it, I don't read 24v.
This is the first Micro800 series I have assembled a I can't find anything in the RA docs regarding this problem. The literature says the 24v is supplied on the bus but I'm not seeing any special device I would need to get it to work.
Thanks Garry!
I searched AB documentation and never found that bit about the open loop detection.
I'm not too fond of this particular Model PLC but this is the first one I've worked with so I'll reserve my opinion till I experienced a few more.
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,025
I haven't had to tune a PID loop in a very long time. It's actually a PI loop for a pulse width modulation s.v. What was the name of that tuning...
4,117
Happy new year everyone. This is more of a Electrical engineering question than a PLC one. Can a Motor and a VFD that is rated for 240/480...
29
9,944
This may be a simple question. I understand the concept and application of analog modules (i.e. Compactlogix) for transducers, and outputs for VFD...
2,098
Good Evening, I am curious to know, if its possible to use PlantPax graphics, face plates in Factory Talk View without utilizing its Add On...
2,273
