Pre-defined lookup table in an AOI.
TConnolly
Apr 2005
Salt Lake City
6,152
Is there a way to create a lookup table in an AOI which has pre-defined default values? I have a 101 element lookup table and I want to re-use this thing so an AOI would be a nice way to go.
I fear the answer is No. (unless I have the AOI write the table on the prescan or something)
Set the default values in the AOI. Every AOI you create will have those values when you create it.
D'oh!
I don't know why I didn't see that. o_O
Done. It was a little tedious entering defaults for all 101l elements but not too bad. Now I can export/import it and will never have to write that bit of software again.
Thanks.
I am trying to figure out how to use the predefined AOI, cant seem to find it in the manual for the add on instructions. Any help out there on a...
1,751
I am trying to figure out how to use a High speed counter module for an incremental encoder. I don't have the exact model number for the encoder...
2,593
Hello all! New user as of a day ago, first post! Just wondering if anyone has ever purchased and / or knows where to purchase a pre-built PLC...
2,896
I am working with a customer template who uses pre and post instructions in Graph. I have not used these before in Graph, and I am trying to...
1,404
Hi Guys, What the quick and dirty way to load a PRE value to a counter in a ML1200 from a C-More HMI? Having trouble using the HMI to reset a...
1,356
