Pressure Sensor with Voltage output
QasimFSH
Apr 2018
Adelaide
142
HI All,
Can anyone please recommend a few reliable pressure sensors, which can provide output in terms of voltages? My plc has built in analogue input slotw, which can accept 0-10v...Btw, I am using TM221CE16R.
Thank you.
Essentially, I have to measure the pressure of a water filled bucket, and evaporate water in order to see change of pressure.
Would a load cell to weigh the bucket not be easier, or is this another one of those wacky projects and ideas your boss has come up with that you "have" to do it this way ?
Added to that voltage? 4-20ma is way better - pretty immune to noise.
Put a 500 ohm resistor across the output of a 4-20 sensor, read it as 2-10VDC.
Or better yet, add the resistor at the plc input to avoid voltage drop, noise etc. This way is actually how many analog 4-20mA input cards handle the signal internally, with a high precision resistor.
No real boundaries set by him at the moment, so its up to me. Can you recommend a few suitable models please? Also, its actually the weight of the Liquid inside the bucket I am concerned with, so that I can keep a track of its concentration.
Thanks.
How tall is your bucket?
I have used an electronic sensor from IFM to measure liquid in a drum about 3 feet tall with good success. At low head pressure, you need a sensitive instrument and onboard filtering is a good feature to include.
http://www.ifm.com/products/us/ds/PN2298.htm
Correct me if I am wrong, You have used this pressure sensor to measure the level of liquid? How much was this sensor for?
I was measuring a liquid in a chemical drum (non-corrosive) with a specific gravity slightly higher than water (~1.2). There is a pump that pulses and causes some spikes on the suction line where the sensor port is fitted, but the signal filtering built into the sensor made that "noise" vanish.
Not sure I fully understand your last question...
The drum is about 40" tall, usually filled to at least 24"(60cm) of head pressure on the sensor.
The sensor cost about US $400
So atm, its jus a flat bucket or container you may call it, that we are using for some experiments. There will be some liquid in the container, and we will heat it. I want to keep a track of the decrease in weight/pressure as the solution evaporates due to heating.
I have a zero center pressure sensor where 0.0 is 12mA, 0.5 is 20mA and -0.5 is 4mA. I cant figure out a way to get accurate results I have...
2,832
I want to measure the level of water inside a closed st.st tank with an over flow opening in the top of the tank at the begining of filling the...
4,740
Dear community, i am new into the world of plc and i have really basic question about the properly connecting of a pressure sensor to a modul...
2,355
Hi all, Trying to find a pressure sensor for an application where the process is running at -100°C (-148°F). Pressure is likely around 1 bar or...
2,943
Hello: We use submersible pressure sensor in oil tanks to monitor the level in the tank. We also have a routine the will estimate the oil...
1,404
