Pressure transducer for a wastewater line
Cow
Jun 2009
Eastern Oregon
102
Does anyone have any recommendations for a good reasonably priced 4-20mA transducer I can use with a VFD running a PID loop on a wastewater line? The system is using a softstart right now, but it's over pressurizing the line. So whatever kind of transducer I come up with will most likely get something welded onto the steel line to mount it. It's a blank slate right now for mounting options.
I've done quite a few constant pressure water systems, but haven't done a constant pressure wastewater system yet.
I'd probably be looking for 0-250 psi or so to have a little buffer in there. I think it'll end up running around 75-150 psi when it's done.
Thanks.
We use "Automation Direct" for almost the exact same thing. We install these in a saltwater tank(oil field injection), then hook to a Schneider Altivar 630 VFD, the vfd is running a "PID" for pumping saltwater back down the hole. This type of operation is very precise it will maintain the level in the tank to almost exactly what you set it at.
Thanks.
I've had good luck with IFM's line of pressure sensors.
+1 For IFM
The PT2424 or PT 2434 should work for you.
https://www.ifm.com/products/us/ds/PT2424.htm
https://www.ifm.com/products/us/ds/PT2434.htm
They have NPT fittings for the process side.
Thanks for the input guys.
I have a rep for Turck looking into a solution now, my major concern of course was plugging. I didn't think a regular transducer threaded into a bung would hold up without having a diaphragm or some sort of seal between the sensor and wastewater?
I could be wrong though. This is cow manure that has had the solids separated from it and then stored in a lagoon where anything left in it most likely settles out. This is a booster pump drawing from the lagoon and sending it to irrigation pivots.
Those gauge isolators are interesting Tom, I hadn't seen those before. I'll have to do some digging on those.
EDIT: Is it really that simple Tom? If I install a gauge isolator, can I get away with installing a regular pressure transducer?
That would be great if I could use the same pressure transducer that we use on water systems.
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,097
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,086
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,431
A little background info I work at a underground coal mine. We have a Dust tank capable of holding 135 tons of rock dust on the surface. We use...
1,676
Hi Guys, Is a typical transducer programmed to output its signal in intervals? Say every 10 seconds it would generate a signal via 4-20mA loop...
1,660
