Pressure Transducer for DeviceNet
I dont know specifically of one BUT you can goto www.odva.org and in the left panel will be a link to the Devicenet Products, which has a catalog. You can look thru it by category, I saw several transducers listed but not sure if its what you want/need.
At first I thought this was a no-brainer type of question, but when I checked the odva.org website as Ron suggested, I found four vendors for vacuum transducers but nary a one specifically for pressure transducers. Go figure.
A Google search using "Pressure sensor" + DeviceNet or "pressure transducer" + DeviceNet yields some possibilities.
I asked the same question here 6 months ago and after searching long and hard there was no such animal. regards Alan
Pressure Xducer
Maybe I'm missing something but how about using something like Interlink BT's BL20-1a1 Link to get the transducers onto DeviceNet as long as there are several it should be cost effective. If you only have 1 its probably too much $$$
It is possible to do it with a linking module but a native devicenet transducer would give you acces to all the other words that are usually inbuilt into these smart devices.
Regards Alan
Good morning everybody, I hope you are very well. I share with you the information of the PLC LOGO! Siemens and expansions that we have...
1,098
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,087
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,434
A little background info I work at a underground coal mine. We have a Dust tank capable of holding 135 tons of rock dust on the surface. We use...
1,680
Hi Guys, Is a typical transducer programmed to output its signal in intervals? Say every 10 seconds it would generate a signal via 4-20mA loop...
1,661
