Edmhydraulics
Hi everyone, I wonder if anyone can help me figure this out. I have a test system that I built for a customer. It has a Red Lion Graphite HMI with an analog input module and 2 - 0-10,000 psi pressure tranducers, 24Vdc input, 4-20ma output. In under a year I have had to replace 4 transducers already. The customer is not overpressurizing them because I have logic in the PLC that prevents this. The test media is normal tap water. There are also standard gauges in the line to give a backup reading to the transducers. The system is pressurized with an air-over pump.
What has been happening is that I have had to adjust the zero points of the transducers a few times before they fail completely, they seem to slowly float from 4ma to up to around 10ma and then get stuck at that point.
The transducers are Wika so its not like they are cheap. I have a switching 24Vdc power supply connected to the incoming power at 220VAC.
Any thoughts on why this might be happening?
Thanks in advance.
Thanks in advance.
